3.0.2 CMS disappeared? Very Strange
Deleted custom HTML
Tired Every Option in settings
elementsapp://downloadDocument/pO2fRR74i7Yv
@dan
Won’t preview - blank…
@MichaelDroste
I just replaced this, not sure this if is your issue
{{item.body | truncate(280)}}
oh no… thank you - just rebuilt and redid the whole cms container…
ended up also getting recovery nodes :frowning:
redid the menu and deleted old
just a mess - combing old site and new together
@dan uploaded to support - recovery nodes deleted, created new menu, created new CMS - still failing
What do you mean, it’s still failing?
What do you see when you preview the site?
Edit: I’ve looked at your site and it appears some (or one of) of your markdown files has an issue in it and is causing the CMS to fail. I’m unsure what file, but I went through deleted batches of files until the site rendered correctly…
Perhaps you’ve added some new files, and one of them is the culprit? Hope this helps.
Well - thank you so much :blush:
After 2 days of trouble shooting with Claude - restructuring all the frontmatter for all 365 files - started your idea of deleting
Narrowed down to 130-140 was the problem
Narrowed down to 135-140 was the problem
Song 138 had a . Instead of a , in tags
Hard to believe one period in one file could take down the entire CMS
Wow :open_mouth:
Thank you so much for your help @dan I would never have guessed the problem or how to troubleshoot - and Claude didn’t know either…
Still some use for us old humans yet!
To be fair we need to make the CMS a little more robust, and report errors better. Look out for that in an update soon.
