A bit more sticky
a little more sticky - elementsapp://downloadDocument/1xwUPEqeq768 accidentally deleted, link in my end post
ok same scroll sticky but all images are random via CMS, 8 images available per area, images not optimised
elementsapp://downloadDocument/0m5X2LZpGJbn
ok switched background for image still CMS, needs more tweaking and adjusting
CMS version with image instead of background elementsapp://downloadDocument/tzZZ9b5mJvxc
accidentally deleted the first one no CMS elementsapp://downloadDocument/VxJVGTWdCqCI
ok last post now, finished with concept, optimised the images for my test before I build properly (started so have format so no need for testing projects) delete projects end of today taking up too much room, especially the videos
project - elementsapp://downloadDocument/gsZr1zOHcI0E the sticky cards title/date (date is pointless but just testing)) are from the md files CMS
my test site - https://sjwjaw.co.uk
ok was finished but not random images just blog both sticky and blog further down, basic but I am still working on the blog at the bottom
project - elementsapp://downloadDocument/TJKkzTFvAlwa updated
Really good work! Thanks for sharing. :slight_smile:
ok couldn’t resist this one, just CMS and Elements, just add a md file or 2, ok if you dont want to show too much on your page, would get very annoying if more than 5, also links to full screen single posts, no real testing so might need some tweaks
project - elementsapp://downloadDocument/qrdV9cQRu7Cl
@PMUK I saw your comic post the other day so created this, 1 - 6 sections any shape, CMS version a lot more difficult as you cant see the image, easy to use once you know how (would never let others try as it would be very confusing), but not finished, it was just a test to see if it was possible, need to simplify at sometime
Amazing thanks I’ll have a look tomorrow properly when at computer. You are AMAZING!!!
