A few minor issues
Using hyphens-auto lang="de" enables hyphenation, but as a result, padding, font size, and centering no longer work.
No thumbnail image appears in the Video component. You have to use a thumbnail image. In Gallery Pro, however, a thumbnail image does appear.
When you click the X to close the video, nothing happens. The click area has shifted to the bottom right.
Gallery Pro zoom function. The image cannot be moved with the missing hand icon. It worked exactly once. However, I can’t find the relevant settings.
Probiere mal hyphens-auto ohne lang="de". lang="de" sollte eigentlich nicht notwendig sein. Zumindest nutze ich das so in all meinen Projekten und habe keine Probleme mit Padding, Schriftgröße usw. Auch ohne lang="de" wird alles richtig getrennt.
Try using hyphens-auto without lang="de". lang="de" shouldn’t really be necessary. At least I use it that way in all of my projects and don’t have any issues with padding, font size, and so on. Hyphenation also works correctly without lang="de".
As a tip, you can also add text-balance to your headlines. Especially when your headlines get a bit longer, it helps create a much nicer two- or three-line heading layout.
Als Tipp: Was du bei Headlines zusätzlich noch hinzufügen kannst, ist text-balance. Vor allem, wenn deine Headlines etwas länger sind, erhältst du so eine vernünftige zwei- oder dreizeilige Überschrift.
Pegasus, thanks for the tip. It works. I thought you had to specify the language so that the correct dictionary could be used.
Still, we should look into why specifying the language has this effect.
