Advanced template and php
Will I be able to add php code using the advanced template?
I use php to access calendar information, etc.
Will I be able to use a relative link to access securely my php connections scripts?
Andy
Yes! You can place PHP code anywhere inside the site template, page code areas, and even in Custom Components :+1:
