Age Verification For Rapidweaver Classic
I’m looking to install an age verification service called go.cam on Rapidweaver Classic. My coding skills are limited so hoping someone can help me on this. Here is the link for implementing-is it possible? https://go.cam/devDoc/
The hosted implementation (Automatic) would be the easiest option for you Go.cam: Developer Documentation | API & Integration Guide - Go.cam - Hosted implementation .
You could just include that one line below I’m assuming since the above docs seems to have gotten cut off when they were trying to write where to include it…
Hi Dan thanks for getting back to me, I think Im getting to grips with whats needed to be done as far as puting the information in the files and putting them on the server but not sure what code your suggesting I put in the body of the website
You’re doing it the complex way then.
This code :slightly_smiling_face:
You shouldn’t need to do the other stuff if you use their automatic hosted implementation from what I can see briefly scanning their docs.
Thanks Dan Yes that works in the body as far as bluring out images (attached) Ive got the key codes registered for the website which I have put in with the code but its not taking me to AV page, I’ll keep at it and hopefully be able toy close this topic.
