Dear @Dan, I’d already activated Claude because, when I upgraded to Elements version 3, instead of the usual AI-related page, I could only see the API request – I’ve sent you a screenshot of it.
I’m writing this after carrying out my first tests by incorporating Claude into my workflow.
As I mentioned in a previous post, I come from the world of audiovisual media and this is the first time I’ve ventured into the web, which I’ve always considered ‘incapable of telling a story’. Elements has made me change my mind and I’m giving it a go. I’m completely incapable of understanding HTML and intend to stay that way. I tell stories through images and don’t want to change careers.
I created a few test pages with images from an old project on Emperor Frederick II, and it seemed to be working well. I activated Claude – certainly not to write text, as I’ve been writing that for over 40 years better than any AI – but to check the tags and minor structural details.
Claude checked everything I wouldn’t have been able to understand thoroughly, but I realised that one component had ended up outside its container – certainly not by choice which I found strange. I put it back in place, then suddenly and for no apparent reason I noticed that on one of the three pages I’d prepared, the 23 Motion Forge Director elements that triggered the background animation when scrolled had disappeared from the Elements editor.
Suddenly deleted – by whom? I gave Claude a telling-off as if he were human, and he told me not to worry: “Everything’s still in the HTML.” In short, the page worked perfectly in preview mode even without the MotionForge Directors. I’m used to mysteries, but not to magic, so I tried to get to the bottom of it by asking questions. Claude started speaking in an unfamiliar language, mentioning “async: false”, “gsap.min.js 36 ms”, “ScrollTrigger.min.js”, “Schema not available for this component type” and “getPageContent”, whilst also claiming Sassano ( @Invisigoth )does not make certain information available.
The moral of the story: it’s my fault – and mine alone – that I didn’t make a backup before running the AI tests; now I have a working page with instructions that I can no longer edit. Never mind – it was just a test that confirms two things: the AI system integrated into Elements is an enormous help and performs functions that allow a traditional audiovisual director to explore the otherwise inaccessible world of the web, but the use of HI (Human Intelligence) must be, and remain, the safeguard against disasters.
Do you think this might be a limitation of Claude compared to other systems, perhaps those integrated into Elements? Do you have any advice for me for the future, apart from making a backup? The page in question is published here
Best regards
Aldo
