I’ll probably not use the API Key anymore. The AI assistant in Elements is a great offering, but since it cost me $25 on the first day for a bit of testing, this service is far too expensive to use. If you use it often, you quickly run “out of money”. I’ll go with using the MCP Server instead, even though it’s a bit more work.
What’s your experience? Are you going to use the Elements AI assistant?
I think it depends a lot on what model you use for the assistant. For example something like GPT-5.4 nano or mini are quite cheap, whereas if you are using the frontier models then yeah it can get pretty pricy. Usually it’s those frontier models that can really do a lot of the build and design work, whereas the cheaper models can be used for the simpler things.
I’ve switched MCP. Not only is it far cheaper, but devoted an on-screen panel to it means I’m squeezing the content area, as I already have multiple panels open simultaneously. While I’ve gotten used to that in XCode and Excel, the number of panels I want open in Elements is far higher, and it just starts squeezing the content area if I open another.
I have Pro because I not only use Claude for Elements work, but for a number of other things like my writing. So what Mike mentions on the Free Claude or lower tier is usually what happens with large usage and you don’t like to wait for more tokens to be come available. There is a current session limit and a weekly limit which if you hit means you will have to wait until they reset. In settings it tells you where your at for both and when the reset. You also have the option to set it up to purchase Usage credits with a monthly spending limit. That is handy if you have a project you are working on and don’t want to wait.
I’m doing the MAX (5x) for now, because it is cheaper for all the stuff I do with my writing and Bible research. Start with the lower account and see how you use it. Again, you can buy Usage credits if you hit a ceiling and need to continue to work, so you don’t have to necessarily increase your monthly plan.
Yes, you can chop and change as much as you like (this is why we have the built-in AI memory), however I wouldn’t run them both at the same time, otherwise they’ll start fighting each other
“It saves time” is only half the sentence, the other half is “compared to what, and for whom.”
It’s a power tool, not a workshop. Use it where it pays, and keep in mind that the real cost isn’t the subscription, it’s your own hours.
If your hour is cheap and you enjoy the ride, the maths works. If it isn’t, a designer who can explain every decision later starts looking remarkably affordable
