AI assistent
I need some help.
I’ve activated the MCP server and asked Claude whether it has access to Elements. It confirmed that it could see the project and asked what I wanted to change.
In Elements, the panel just shows “Set up the AI assistant.” I can’t type anything here.
What have I done wrong?
If you are using the MCP Server you have to use Claude Desktop to enter your Elements related prompts - that is why it says "Connects Claude Desktop to the RapidWeaver Elements App …’ :thinking:
I forgot to add the API key.
