Align Sub Menus
I’m using the Fixed Menu from the Core Templates. Here’s my live site.
As you can see, the top level menu items are aligned to the right, and the “Issues” item has two sub menus.
When you navigate to the second level sub menu, the text goes off the edge of the screen. This is not an issue on the mobile nav.
What is the setting in the Menu component to move the 2nd level sub menu so it shows on the screen?
Unfortunately there’s no option to fix this at the moment.
To fix this right now you can either move the pages around so the Issues page is first in the page list, or align the menu items to the left.
I’ll add a ticket for us to investigate this Menu component issue and see if we can fix it in a future update!
Thanks, Ben! I’ll center align until the fix works its way into the queue.
