On my Education page, I put anchors in Marquee Pro scroll at the top of the page. The anchors work on desktop but when I try in IOS on my iPhone they don’t work. elementsapp://downloadDocument/QLtzOzOjuOnI
not helping question but brilliant website, looks amazing. Just a help for going forward, you have three HTML custom components and they are called HTML and HTML box. If you double click on heading you can rename them as in future you may “forget” what they are, also if you need to copy one into new project don’t have to open them all to find out what they are.
Also great to see you “substack” stories are working.
Great site well done!
Thanks @PMUK! Yeah I made those HTMLs and then ended up not using them.
Some links to Substack are working but somehow others broke I have to reset. I created a global of that Marquee and I may not have put the links in the original global or something. The page is still in rough draft but it’s getting better I think. Slow migration from RWC.
Hopefully I can sort my Anchor in iOS issue as well.
This looks like a bug in Marquee Pro on iOS devices. I’ll add this to our bug tracker and see if we can get it fixed ASAP.
I’ll update you here once the fix is live on the store. Apologies for any inconvenience.
Hi @ben I’m circling back to see if there is any update on when you might be able to get around to fixing the anchor not working in Marquee Pro in iOS.
