@dan I noticed today that setting an anchor ID on a Background component doesn’t appear to work. You can never access the anchor value from the anchor popup in the Link dialog. Switching to a container worked fine, but it seems this should work with a background component.
Ah that sounds like a bug in the component! I’ll get @ben fix that up (hopefully for tomorrow’s build).
This is fixed and will be included in the next build ![]()
