Good morning,
Is it possible to take over a color palette from another project?
And if so, how?
Best thanks
See the hex code under the colors?
While not ideal - you could copy one code and transfer that to the new color scheme in the other project
Okay, that’s what I’m doing right now. But there is probably no other option.
But thank you
I’m using the same way like @MichaelDroste. As far as I know there is no other way.
