Article Modal under 3.0.11
Hello everyone,
Unfortunately, the Article Modal Template does not work under 3.0.11.
Can anyone confirm that? Not even in the preview.
Yes, I can confirm that. Article Modal isn’t working for me either in version 3.0.11. Even the original example doesn’t work. I’m writing a message to support right now.
Awesome :+1:
There is an update that works with 3.0.13.
Is there a sample file? Link … @1LittleDesigner
@PLM yes there is. I had trouble finding it, but then I found lots of sample files for components I’d downloaded!
Go to File > New Project, then in ‘Your Library’ click View All
You’ll then find the Article sample file:
@RichardPhoto Thanks. Does Artical Modal only work with Elements CMS? I want to use in Elements.
@1LittleDesigner
@PLM You don’t have to use it with CMS (the free version comes with Elements) - you can use your own content. The project file includes examples that use non-CMS content in a modal. :slight_smile:
