Ask for Tabs inside Elements
Hello, One of my customer is asking about horizontal Tabs in an HTML page, is there a simple way in Elements to add tabs using an existing component ? Or may be how to do that using TailWind ?
Thanks for answer.
Francis
Would ‘top pages’ work ? ( … not ‘top menu’)
Can you drop this;
Into a custom component? Create an HTML component and add the code from this page
I will try thank you very much!
