Aspect Ratio Bug
Hi, I think i have found a bug. Im trying to align an image with the amount of text in a 2 column component.
When i try to manually change the image aspect ratio at the different breakpoints it stop responding on the screen. If i delete the image container and start again it works but then breaks when trying the same thing.
Chris
are you selecting the break point dots and changing them to blue to keep those settings for each screen size
Yes. But when you change the ratio. Nothing happens.
@Cablecar69
not sure if this what you are looking for
the blue dot is difficult to see, were you checking the one above
Hi thank you for the video. that was what i was doing but it wouldnt work. So i deleted the image component and re added it and it worked so thank you again.
I must have changed another setting which was stopping it working.
