Aspen theme remove footer info on menu
hello just got Aspen theme . How do you keep the footer info and not show on the top right of your site ?
Uncheck this:
on the general page
Well sure but I want to keep my footer ? so Ihow do I do this ?
You might need to talk to @dan
Hey @ocean
Sorry for the late reply. Try this…
In Master Styles check “Hide Header Contact Info” under the “Hide Toggles” section.
Hope that helps.
Dan
Thanks Dan
THANK YOU , IT WORK…
NOW WHEN I CLICK ON CONTACT IN THE FOOTER…IT GO TO A PAGE …? NOT TO EMAIL ? http://www.kcschulberg.com
Check the naming of your folder!!!
Attachment available until Aug 13, 2021
Click to Download
contact video.mov
129.8 MB
Hope this helps.
Thank you it work…ok how do you keep like Aspen as a master style?
Not sure what you are asking???
So I look everywhere ?? In Aspen, how do you do Parallax …I see for banner disable Parallax for banner but not sure how to create parallax ?
No idea
