Auto correct year in footer
@elementsbot, I tried to make a custom HTML component for my footer so that the copyright date was always the current year. This is not pulling in the javascript current year. What am I doing wrong?
&copy; <span id="year"></span> Generations CryoVault, LLC • All rights reserved
Hey Charlie! Classic gotcha. Elements will often hoist/move inline scripts, so your JS can run before the footer exists. Two easy fixes:
Easiest: use Alpine (built-in to Elements)
No separate
Why this works: per the doc.txt and the Elements Manual (Template and Hooks sections), scripts can be consolidated/relocated (e.g. head/body injection points). If it fires too early, your #year span isn’t in the DOM yet.
Bonus (component-y way): in your component’s hooks.js
export default ({ el }) => {
const year = el.querySelector(‘#year’);
if (year) year.textContent = new Date().getFullYear();
Any of those will do. I’d go with the Alpine one-liner. Elements Bot approves this footer sorcery. If it still misbehaves, ping me (or @ben). And reminder: I’m an AI gremlin — I can be wrong, Elements changes fast!
Like this?
&copy; <span x-data x-text="new Date().getFullYear()"></span> Generations CryoVault, LLC • All rights reserved
Yep — that Alpine version is spot on. No extra needed, and it’ll render the current year reliably (see doc.txt + Elements Manual: Elements Language/Alpine bits — inline scripts can move, Alpine avoids the timing gotcha).
Tiny polish to prevent a “blank flash” before Alpine kicks in:
  • Add x-cloak to the span
  • Add a one-liner CSS
HTML:
© Generations CryoVault, LLC • All rights reserved
CSS (Site > Code > CSS or Theme Studio > Custom CSS):
[x-cloak] { display: none; }
Optional: put x-data on the footer (as above) so you can reuse values if you add more Alpine bits later.
If anything still acts up, shout and we’ll poke it with a stick (cc @ben). I’m an AI gremlin — could be wrong, and Elements moves fast! For more, see the Elements Manual and doc.txt notes on scripts/portals/hooks.
This is not showing a date in my live update and it doesn’t show anything in my preview (I don’t even see the Generations CryoVault text)
Gotcha, Charlie — if even the plain text isn’t showing, this isn’t just the year logic. Likely the component isn’t rendering (or it’s hidden). Let’s sanity-check fast.
Do these in order:
  1. Quick static test (no JS, no Alpine)
  • Drop an HTML Component on the page with ONLY:
If that doesn’t show in Live Update/Preview, the issue is placement/visibility: - Make sure the component is actually on the page (not inside a hidden container or breakpoint-hidden). - Check Responsive/Visibility toggles. - Ensure you’re using an HTML component (not the Code/Markdown component).
  1. Alpine version (clean and reliable)
    HTML:
CSS (Site > Code > CSS): [x-cloak]{display:none;} Notes: - Put x-cloak only on the span. If you put it on the footer, it will hide the whole thing until Alpine mounts. - Alpine is built-in (per doc.txt and Elements Manual), so no extra
Inline scripts can be hoisted/moved by Elements (see doc.txt + Elements Manual: Elements Language/Portals and Hooks), so firing after DOM is key.
If step 1 didn’t render anything, can you share a screenshot of the component tree (and confirm it’s an HTML or Custom Component, not Code)? If this still misbehaves, ping me and I’ll rope in @ben. Also, I’m an AI bot — occasionally wrong, and Elements evolves fast. For reference: see the Elements Manual (Elements Language, Custom Components, Hooks): Welcome | RapidWeaver Elements Docs and the notes called out in the doc.txt.
okay it displays but I’m not getting the date, so the Alpine is not working?
If the footer shows but the year is blank, Alpine likely isn’t mounting on that component (or x-cloak is hiding the span because Alpine never starts).
Quick checks:
  • Make sure this is an HTML component (not Markdown/Code).
  • Temporarily remove x-cloak from the span. If the year suddenly appears after a moment, Alpine is working but you need the x-cloak CSS. If it stays blank, Alpine isn’t mounting there.
Known-good Alpine version:
Then Preview in Browser (not just Live Update), and check the browser console for JS errors that could block Alpine.
Rock-solid fallback (no Alpine):
  • Page > Code > Body End, add:
  • Your HTML component:
Why this works: per the uploaded doc.txt and the Elements Manual (Elements Language: portals/hooks), inline scripts can be moved/combined, so running JS at Body End avoids firing before the DOM is ready. Alpine is bundled by Elements, but if a separate JS error occurs on the page, Alpine won’t mount and x-cloak will keep the span hidden.
If that still fails, can you share a screenshot of the component tree and the console error from Preview in Browser? I can poke it with a stick or summon @ben. Also: I’m an AI gremlin — might be wrong, and Elements evolves fast. For reference: Elements Manual Welcome | RapidWeaver Elements Docs (see Templates, Portals, and Hooks).
Hi @Jupeman do you have a live URL or an Elements project you could share? I can then take a look at why this isn’t working for you :slight_smile:
It won’t show in Edit. You’ll need to Preview the site in the browser to see the date. Does that help?
EDIT: Just tested the following code and it seems to be working nicely…
Boom, that “x-text” addition made it work. Thank you!
