In RWC the background stack I used had the capability of adding an overlay. It was a nice feature that allowed me to slightly darken the image behind it. Will an overlay option be added to this component or is there a workaround?
Right but does the container work in the same way as a background? With the background it looks like the page kind of “opens up” to reveal a background as you scroll down and come upon the background.
Just place a Container inside the background, and then set a transparent colour on that ![]()
Once you get used to Elements you’ll find you can combine all sort of components to do things you want, we’ve built it to be much more flexible than Classic ![]()
Ah I had “dark mode” toggled on. It was showing me dark mode in Elements and then when I previewed it showed light mode. I fixed it.
