Beta 36, Accordion
Is it possible to start with all boxes open as default and not closed?
Hmm, we don’t have that feature built in right now.
I’m also thinking that starting with all the Accordions open defeats the purpuse of accordions… Why not just have a simple on page Q&A built with text?
It was resolved by using Cards :slight_smile:
Ah, that’s great to hear!
@dan I have a problem with Cards that I hope there is a solution for. Is there a way to hide Tags (Cards) that are not selected?
I am using Filter and File Tags as in Tag Demo
Try changing the transition from “Fade” to “Slide” on each card.
btw. These transitions are not final, we plan tweak them and add some other options, but the slide should give you the effect you’re looking for!
Let me know how you get on.
Unfortunately it didn’t work.
You need to make sure they all belong to the same group… Can you share the project, I’ll see if I can fix it up for you?
Got it.
I set Container to Custom and Group ID and Accordion to Parent and Slide
They need to be in the same filter group, so set the Custom “Group ID” to be the same on all of them, i.e. Custom > “produkter”
