Beta 7 won't open existing Project
Version 10 (22877) BETA (Plus license)
Tried to open existing project and it “can’t be opened”
Is that ALL projects? If you download this sample project, does it open?
Can you send us the project that won’t open so we can take a look at fixing it for you? Send it over to dan@realmacsoftware.com :+1:
Sample Project Opened. Project too big for email. Do you have another method of getting you the project file??
You can use an online service like WeTransfer, it’s free to send files…
sent file
Thanks, got it. Will dig into it shortly and see if we can get it back up and running for you!
Thank You
Ah-ha! We’ve taken a look at the project and found the issue :sweat_smile:
We should have a new build out later tonight (or tomorrow, UK time) that will allow you to open your project.
Sorry for the disruption!
Hey @sbchasin,
New build is up, check for updates (build 22879). Your project should now open :crossed_fingers:
Fixed, Thank You!!
