Big mess
just copy the link in the forum
When all else fails, follow the instructions…
elementsapp://downloadDocument/dbzYqSmOVEWI
Not sure if it helps but, if I use Safari/Safari Technology Preview I get the same issue, disappearing after a refresh.
If I use Opera, which I normally don’t, I don’t get an issue, even if I refresh many times ??
Thanks Russ, it’s a possibility, but unfortunately, I can’t count on customers or prospects using that particular browser. It’s gotta work all the time.
I was just mentioning it in case it helped with debugging.
Is there anything in the server logs?
I find Elements totally unusable. Sorry I purchased it.
ive used blocs sitely rw classic and elements is by far the easiest to use..admitedly perhaps others have more options at present but cant believe how hard others make going through the breakpoints etc
What, exactly, do you find unusable??
I have tried many other web design software packages, and Elements is the first one I have liked since GoLive. It was the first one that I have been able to successfully re-create my website (that was originally built in GoLive).
Interesting to know what you find unsuitable about using Elements
Without knowing what are are trying to produce difficult for anyone to help
Bearing in mind web pages are mostly menu text images and videos etc
There are additional features that are available within Elements with much more in train
Few hours of understanding, most components have similar options once you have been through those options you almost know every component
Grid and flex are powerfull and do pose a learning curve but have been made simple out of the box
Plenty of help on this forum
The latest resources and projects have introduced just drag and drop page building
I have lots of web building software finding Elements really intuitive and enjoyable to use, in my my opinion the best of all of them and not even finished yet
I am trying to add video to a web page and seem to be unable to do so.
is the video on your local drive
or external YouTube etc
Local drive
I dropped my video into resources, very simple setup
just dropped in page could be grid container flex etc
video is me on my paddle board
link to manual types of video
https://docs.realmacsoftware.com/elements-docs/elements-app/components/built-in-components/video
in a container grid 4 rotated
