Blueball Freestacks query
I’m having to pickup Rapidweaver again after many years away. Thought I was done with websites but apparently not!
So I believe that Blueball Freestacks is no longer running? Does anyone know of any similar alternative that will be fairly simple to pop in it’s place?
I feel like I’m starting all over again!
I have a couple of old @blueballdesign stacks, but not sure they’ll be of much use. Let me know if you’d like me to share them…
If you’re not quite done with building websites, you might want to take a look at Elements :smiling_face:
It has pretty much everything you need built-in, it’s also a true WYSIWYG editor, so makes building sites much easier!
Check out the getting started video for a quick look at how things work in Elements…
You can also download a free trial to get comfortable with how it all works before you purchase, there’s no time-limit to the trial so you can take your time :slight_smile:
