Border Opacity Not Working to Navigation Component
I’ve added border in the bottom and then added opacity to the navigation bar component. It was working fine in the beginning but then I saw it stopped working. Then I remade adding a brand new Navigation component, and it starts by working but I found that when I got to the stage I was before, it was not working again.
For me it is only not working in the Navigation Component. but it works normally in other components.
Hi @vinioliv
I can’t replicate this issue unfortunately. Do you think you could share a project where this is a problem?
Thanks :slight_smile:
Here it is @ben the Website. Checkout the border’s opacity from the navigation bar. I’ve tried doing a new one and this is the second.
I’ve managed to replicate this one, and we should have a fix out in the next beta :slight_smile:
That’s fixed.
Amazing, Thank you!
