Broken images and alt text
Just updated my OS mac OS Mojave (ver 10.14.4) now my website auditor shows I have numerous bkoken images and missing alt text, I check over and over and can’t see any missing or badlinks.
You’ll probably need to provide folks a little more info about the problem for them to be able to give you any solid advice. Usually the more info you can provide, the better the advice you get back will be.
  • the website URL
  • a screenshot
  • details of which links your auditor says fail
  • any other info about the auditing process
