Bug in Layout Editor
When working in the layout editor while adding content there is a very annoying bug that dramatically impacts your workflow.
When I’m on a page with a lot of content and I’m in the process of adding new content towards the end. In my case a card component. I need a an image resource that will go in the card. I head to the resources and add the required image (in my case a remote one). After the resource has been added the page is reset to the top. So now I have to scroll all the way back down to where I was working in order to drop the image in the card’s image well.
This gets old very fast as I’m working mobile first so the page can be very long if there is a lot of content.
Is this a known problem, and if so, can it be fixed?
As an aside I have found when working with resources you do not want to attempt to perform an UNDO as this will crash Elements.
I have seen something substantially similar. I will sometimes select a component in Layout View, and it then jumps up. Not always to the top, but it jumps up substantially.
I haven’t been able to reliably reproduce it.
