Bug in Transforms Settings
Hi guys,
I am just working on some hover effects in Elements. I am using very often the Transforms settings. Now I came along the second time in what I would guess a bug.
In the below video you can see what I mean. When I want to shift a text in the hover state by a certain pixel amount this is not working with various values on various breakpoints. It takes only one value over all breakpoints no matter what I am then keying in. In the example below its the Horizontal setting, but it is the same vertically.
That does seem a bit iffy, I’ll get @ben to take a closer look at this and find out what’s going on.
Hi @ben and @dan
is this still under investigation? It simply does not work (at my end).
@ben is away for a few days, but don’t worry, there’s a ticket for the issue so we will get around to it once he’s back :blush:
This one will be fixed in the next update :slight_smile:
Super @ben, thank you!
