I bought the CMS and have been working on it with Claude and really like it. I am no wizz, so this is not coming from me but from AI!
Ahrefs flagged broken images and issues with the blog pages. I couldn’t find what the issue was and thought I had set it up wrong, so I left it at that.
I worked with Claude on schema and open graphs, and Claude found the errors.
Bug 1 — {{page.opengraph}} merge tag breaks when a page’s OG fields are empty
Here is Claud’s summary: When a page has no Open Graph values set in Page Settings, the {{page.opengraph}} merge tag (used in the site Template to auto-output OG meta tags) doesn’t fail gracefully — instead of omitting the tags or outputting safe defaults, it produces malformed or broken output that affects the rest of the page’s .
Bug 2 — Resource path duplication for uploaded images
Images uploaded through Elements’ Resources panel and referenced in custom code (e.g. manually-written og:image meta tags, or JSON-LD thumbnailUrl fields) sometimes publish with a duplicated path segment, producing a broken URL that 404s, even though the same image displays correctly when placed via Elements’ normal image component.
Claude found a workaround for me, so it’s not urgent, but I thought it would be good to report here to get it fixed.
