Bug - Smart Publishing republishes unchanged files locally and over FTPS
In Elements 3.1.3 (build 24707), Smart Publishing appears to republish unchanged files, both locally and over FTPS.
In a local test, two consecutive normal publishes with no edits between them:
  • Rewrote 60 of 61 .asp pages with identical contents.
  • Rewrote all 61 CSS files: 47 had different contents, while 14 were identical.
“Clear page status when publishing” is enabled. This happens using the normal Publish button.
As a followup on this - the publishing was to a staging website on my webserver. I added a new destination - the production website on that same webserver (IIS). So the destination is the same Windows Server running IIS, just on a different IP/host name on the server, and a different website in IIS. Both staging and production website are using the same application pool. Both publishings are done via FTPS (not that it matters, since even exporting to a local folder on my Mac results in almost all files being re-created).
But the surprise was that today on that new destination (the production website) the smart publishing works just fine. Only the modified pages are being published. And if I select the other destination… the issue still occurs.
