Building bricks
ok might be of use lots of combinations 1 line of code
what can you make a little fun before the arrival of Elements 2
component in this project
added wrap
possible chaos gallery
over the top with blue dots
play with the gap
Working on gap
The new dynamic drop zone feature in Elements 2.0 is definitely going to help you with creating custom components like this :star_struck:
@dan I looking forward to that stopped some of my components to incorporate, will add lots options, have lots of ideas
Awesome :smiley:
updated gap, not tested
thats adds flexibility
add flex in flex then add colrow crazy layouts
one line of code a dropzone and Elements and only 4 controls
This is so brilliant Love Elements
so quick chaos gallery
add some text
You still have blue dots in Elements components and transform etc
The wall is just 2 svgs and ColRow
last go need to delete free up space
free component and project examples - delete all tomorrow
quick check it works uploaded
https://sjwjaw.co.uk/Chaos/
ok updated with image slider and an extra page to see how I could start to create a footer, very basic, definitely last one now footer easy in Elements anyway
component download with project
elementsapp://downloadDocument/WiUhUpTXAo97
ok you cant have a brick wall without it being built first
Can’t have a brick wall without foundations and bricks either!:joy::joy:
Foundation is Elements​:joy::joy::joy::joy::joy:
