Button not showing
I have a site
etkworks.com.br
In the project the Whatsapp button in the Mobile Menue shows just fine.
But, online, the svg is out of the button.
Something is wrong in the project but I dont know how to fix it.
I already did a “recovery” thinking it would rewrite the Tailwind code.
Any hints?
I saw this in another post about buttons, don’t know if it will help but worth a try I would think…
“Under Advanced in the button settings add ‘text-center’ for the CSS and it will work”
This is the Advanced tab at the bottom of the button setting. Good luck :+1:
Hi Al
No.. it is some bug out of sync in the code that ELEMENTS writes. But I do not know how to fix that.. I will probably destroy the global and restart the Mobile Menu from scratch.
I tried your suggestion.. thanks..
Hi Pierre,
That’s a shame but it was worth a shot I guess. Has it worked and has gone wrong as the build has progressed, or has it never worked
I deleted the Global “Mobile Menu” .
Created a new one, ajusted it correctly and only then named it a global and put it on all other pages.
My attemts to change anything inside a global Menu.. would always lead to corruption>
When I deleted the corrupted Global, on all pages where some dummy signs saying “recover” or soemthing..
I think the making a component global, makes it more tricky to adjust.
Yours P
