Can I create my own Elements theme?
I understand that I can select a theme and then customize it according to my preferences for colors, fonts, and other elements. However, is it possible for me to compile all these modifications into a new theme that I can reuse?
That’s a good question. Things have been pretty quiet on this topic lately. There actually was some communication that the ability to create your own Elements themes would be enabled at some point…
If you right click on “PROJECTS” on top of core bits you can name a folder for example “My Theme” build your page with your theme and copy the sections into you folder. On a new page drag the folder in to the page and you have your theme that you set up loaded into that page. I dont think this is the “Theme” that we’re waiting form but works for now.
We haven’t opened up that feature just yet as it requires a little more polish, but it is coming soon-ish!
