Cards design
Hi again,
here is my second problem, also connected to screen sizes changes.
I would attach a couple screenshots to try to be clearer, but I get noticed that I can’t upload media to a post (maybe i’l using the wrong button?)
Basically it’s like an horizontal card with a text part on the left and an image on the right. The background of the text is orange. At the starting point, the are both in a container and in a flex and have a perfect rectangular shape. When I start decreasing the screen dimension, their dimensions change different so it’s an unpleasant sight. I wonder if there’s a smarter way to keep the same design when the screen gets smaller, but it is not so small yet to have those elements (text + picture) to appear in a column instead of in a row.
I could make copies of it to be visible or invisible depending on the sight, but that would make it very complicated to use and update afterwards.
Thanks to anyone who can help.
Yes, this is absolutely possible using the responsive design controls, you can make the text size smaller on the smaller screen sizes.
Take a look at the responsive design video in the manual.
Let me know if you need further help after watching that :slight_smile:
