CDN Getting a Warning triangle With Exclamation Point in Elements
First time using a CDN set up a CloudFlare R2 Bucket, Changed Nameservers, Changed DNS
It appears to be working:
https://media.windytown.com/01 Earth Food 01012006 OneSongEveryDay.mp3
Disregard warning triangle?
Or?
Thanx :slight_smile:
Got 365 Songs to do - Want to make sure they are correct… before continuing
Ah, we might not handle showing an icon for remote mp3 files yet… Does the remote link work in the audio player? If yes, then you’re all good to go.
We’ll go ahead and get this little icon display bug fixed.
Yes :+1: it works thanx :slight_smile: wanted to make sure before doing 365 mp3s :slight_smile:
