Changed Files Not Being Published?
@tpbradley
Very unfortunately, in the beta version 3.0.9 this correction seems to have regressed. :worried:
First off, I would like to go back to beta 3.0.3 and use Claude to test this again on that version. I can’t find a link to in the previous versions list, only V2 of Elements.
@dan is there a link to the beta versions?
However, the project I previously sent you will demonstrate the error in the 3.0.9 beta.
Just to reiterate, I think a Publish All should republish everything including assets. :thinking:
PS: Updated to remove the SFTP issue as that was our (Myself and Claude’s) fault.
@tpbradley / @dan
Post above updated to remove the comment about production issue.
I have sent a revised .MD document to support that updates the error description. The error can still be replicated using the project I sent you.
Hi @dan / @tpbradley
Did you get my revised document on this bug via support?
Just checking. :slightly_smiling_face:
Hey @logrunner
Sorry for the delay, been super busy. I have the document you sent — I’ll try to dig into this today.
Cheers
OK, no rush, I was just checking that it hadn’t got lost. :slightly_smiling_face:
Hey @logrunner
Sorry it’s taken a while to get to this!
Hopefully 3.0.17 will fix this problem for good: Elements 3.0.17 is Now Available
Cheers
Thanks @tpbradley
I’ve retested on 3.0.18 (build 24628) using the same publishbug pack from post #17 — publishing to a local-folder destination and editing only shared/assets/version.php unless noted.
Publish What changed beforehand How it was triggered Deployed version.php
1 nothing (first publish after updating to 3.0.18) MCP :white_check_mark: refreshed — but rw/version.txt was rewritten too (24622 → 24628), so this was the post-update full republish, not the fix
2 version.php edited while Elements was running MCP :cross_mark: stale
3 template edited in the same pack (visible HTML comment) MCP :cross_mark: stale — though the comment did appear in the published index.php
4 quit and relaunched Elements, no edits at all MCP :white_check_mark: refreshed, with rw/version.txt untouched — so not a forced full republish
5 version.php edited while Elements was running Publish button :cross_mark: stale — identical to row 2
On the trigger: rows 1–4 were published through the new Elements MCP server (I’ve been driving this project with Claude Opus 5 via MCP), so I added row 5 as a control — pressing Publish in the app myself, same conditions as row 2. Same outcome, so the trigger isn’t a factor.
I ran the same sequence on 3.0.17 with identical results, plus one extra case there: closing and reopening the documentwithout quitting the app changed nothing.
So the “source newer than export” comparison looks like it runs when the dev pack is loaded at app launch, rather than at publish time: any shared/assets edit made while Elements is running doesn’t reach the server until the next relaunch.
One other thing that looks like a regression: previously, changing a template in the same pack forced that pack’s assets across in the same publish — that was the workaround I’d been relying on. On both 3.0.17 and 3.0.18 it no longer works (row 3): the template change reaches the page, the assets don’t.
The pack and project are unchanged from the ones you have apart from the version string, so the repro is: edit version.php, publish (stale), quit and relaunch, publish (fresh). I’ve left mine in the mismatched state (source v2.3, deployed v2.2) if that’s useful.
Happy to send the files again.
Hey @logrunner
Thanks for the thorough retest, really helpful detail. I’ll dig into this again.
Cheers
