Hi
Just getting started with Elements 2.0. I’m using the theme Build and the Standard menu project.
The hover link color in the menu is Blue, but I want to change it to another color. How do I do it. I can’t seem to find it anywhere.
Tina
Hi
Tina
Thank You So Much
I want the default color to be black and active to be black too. But how to I change the Hover Color.
Don’t think you can do that with the current controls
At the moment, the menu only exposes Default and Active link colours. The Active colour is also used for the hover state, so there isn’t a separate control for hover styling in the current menu component.
If you need full control over hover, active, and default states, the best option is to build a custom navigation using Containers, Flex, and Text. That approach gives you complete styling control and is ideal if you are not relying on sub-menus.
Hi Dan
Ok. But do you think it’ll be added to the Menu component soon. I have submenus, so ir’s not a possibility for me to make one myself.
Best
Tina
fre. 6. feb. 2026 kl. 13.18 skrev Dan <notifications@realmacsoftware1.discoursemail.com>:
