Charset declaration is missing
… or (rather) occurs too late in the HTML is what google’s Lighthouse / Page speed says:
When inspecting the code it’s clear that it comes too late in the html, given all the scripts that are loaded before the charset declaration.
Never had that problem with any other web builder before, can’t remember to have seen that even with classic. Can that somehow be changed? It works when I manually move the charset declaration above the script tags.
You are able to re-arrange the template how you see fit here. Apologies if you’re already aware of this and meant the default template should change.
Settings > Template:
@ben Can you change that in the default templates? And perhaps communicate to the Devs that this is needed for all templates, if not done so?
