β˜… Clipboard β˜… πŸ“‹ πŸ’¬ and it does more than you might think
Hi Guys, after Typewriter recently released, I’m happy to present Clipboard :smiling_face_with_sunglasses:
Clipboard is a component that lets visitors copy text with a single click, but the real value shows up once you drop it into an actual page.
The core idea is simple: click, text lands on the clipboard, done. No manual selection, no keyboard shortcuts. But the how is where it gets interesting β€” you control exactly how it looks, how it behaves, and how it confirms the action to the user.
For plain text
Coupon codes, IBANs, email addresses, long URLs, config strings β€” anything a visitor needs to copy exactly right. You can display a readable label and silently copy something different behind the scenes. The click target can be the button, or the whole text area, or both. The demos show this better than any description.
clipboard_multithemes_004
For code
A dedicated monospace block with a header bar, language label, and optional icon. Paste any snippet in, it renders exactly as entered, line breaks and all. Long blocks scroll inside a capped height so they never break your layout. Again β€” check the demos.
clipboard_multithemes_003
What you can tweak
- Five layouts: inline with text, overlaid on content, button below, appears on hover, or a full code block with header bar
- Three independent feedback signals: tooltip, label swap on the button, blink on the text β€” mix and match as needed
- The tooltip animates in with five entrance styles and disappears after a delay you set
- The button shows one label before copying and switches to another after β€” fully editable
- Clicking the text area itself can trigger the copy, not just the button
- Full styling control on everything through the inspector β€” no code needed
clipboard_multithemes_005
Available int the marketplace
Now in promo!
thanks
It took me a minute to understand the use case. Thats a little gem :+1:
Thanks Markus, it’s actually a component that works in a particular way, so understanding its usefulness is not immediately clear, but it can be very useful
Clipboard is AI-ready :light_bulb:
New in Build 5: Added Elements AI support, this update makes Tour fully compatible with the Elements AI Assistant. Every option now carries a clear, plain-language description.
Describe the result in one request, even a detailed one: the AI sets the layout, the text, the feedback and the style together.
Example: β€œAdd a 20% discount promo with the coupon Save20 in a dashed yellow box. Let visitors copy it by clicking the code or the β€˜Copy coupon’ button, then show a tooltip saying β€˜Copied! Use it at checkout’.”
Take a look at the demos :magnifying_glass_tilted_right:
if you already have, make sure to update it! :up_arrow:
thanks!
