Closing Elements project and save
have you changed how Elements saves a project, previous even if I didn’t make a change I was asked to save, now I close a project I’m not prompted, not sure I like that, always like a reminder
Element will prompt you if you’ve made any changes - Are you finding that’s not the case?
no asks if I made a change, before it was prompting even if I didn’t make a change, no issue
Yes, that was a bug we fixed in the last beta. It won’t ask anymore, sorry you don’t like the change, but I think it’s the right thing to do (it’s how all other apps work). You’ll get used it!
