This is the working CMS that I copied the container from
I’ve checked paths - deleted redid
quit and restarted…
getting a mess
Any Tips?
Did you rename your site from index.html to index.php?
YEP - forgot that!!!
Totally Works
deleted old folder off server with index.html - republished 3 times
Because of only 1 entry? Causing issues?
Possible conflicts? Old 1500 file upload now 5000+ file upload?
I know it’s extreme - but going to try and delete whole folder from the server
Load the fresh 5000 file version…
Well - crap - was going to take down the forum anyhow - but accidentally select A-S folders and deleted Forum ![]()
