I have a CMS collection sort by Published Date, but I want to pin some posts to the top (overriding the sorting order)
Could someone pls. tell me how to do it?
Or give me some links to learn.
TIA
How many posts, and will they always be pinned or will you change the pinned posts
I want to pin 2 posts. Yes, I want to change the pinned posts.
Thanks!
this is one way there are other ways - elementsapp://downloadDocument/mda6334rnw1C
I just used featured true and false and used the same collection twice, I also made the first collection sticky
if you set featured both in the second collection it would show the true and false
, so all the posts, but still keep the two at the top
if you set 4 to true 4 would be pinned
Thanks a lot for your help!
