If I have the pagination setup on my blog page to the exact number of actual posts or more, then it effects my menu. As you can see the drop down boxes from the menu stay there. Any ideas? I’ve uploaded my project to elementsapp://downloadDocument/JtHyKczbVonH
You need to do a a couple of things to fix this:
- If you want to use the Pagination Component it should to go into the After section on Post List.
- Don’t use Load More and Pagination together, there’s no need for it and it doesn’t make sense
If you do the above two suggestions your issue will be fixed ![]()
EDIT: After more testing, it appears there is a bug when using Pagination with drop down menus. We’ll get this fixed and ship a new build shortly.
