CMS Templates?
While CMS technically works, I have been waiting since last summer on a set of templates that reduces friction in using the CMS functionality in Elements.
Am I alone in waiting for this? Or has is become available somehow without me noticing?
Best regards,
Kjell Are
Not sure what you mean here, particular with your use of the word “templates.” As I outlined in my Little Book of Elements, start with the MicroBlog Project, which is 100% working. Once you understand how that Project works, transfer that knowledge to the site design you’re working on.
If you are looking for something a little more sophisticated, you can try what I did. I purchased the Maximillian template, studied it, then built my stuff from there. It was worth the price.
