Blumik
(Mike)
May 20, 2026, 7:15pm
1
That’s nice; but unfortunately it doesn’t work at all as shown in the first video.
I created a page “Edit” and then pulled in online editor and published. But unfortunately I only see a white page, what am I doing wrong? Somehow comes to another container, subfolder … no matter how I do it, it doesn’t work.
Or is it not for the public?
The page is : Sumiside.de
Beste Grüße
Mike
dan
(Dan)
May 20, 2026, 7:21pm
2
Ensure the page extension is set to .php, if it’s already set to php try re-publishing ALL files.
If you’re still having issues, please send your project file to forumsupport@realmacsoftware.com and we’ll take a look
Blumik
(Mike)
May 20, 2026, 7:33pm
3
So I have now thrown everything down from the server again.
Looked if all pages are on php (yes you are) but unfortunately not possible.
What else can I do
Have now sent the file to forumsupport@realmacsoftware.com .
dan
(Dan)
May 20, 2026, 9:52pm
4
The project looks fine, I’m wondering if it’s to do with your hosting setup… Who do you host with? And do they support PHP 8.4 or newer?
@ben any ideas on this one?
Blumik
(Mike)
May 20, 2026, 10:44pm
5
I’m at Strato. and I tried the PHP version 8.4 and also 8.5 and both don’t work
ben
(Ben)
May 21, 2026, 2:09pm
6
I’m pretty sure the issue will be to do with the security settings on your host, most likely very strict “mod_security” rules.
We have an update coming out today that will hopefully help with this, keep your eyes open for the update, and re-publish all files after updating.
dan
(Dan)
May 21, 2026, 4:49pm
7
@Blumik Please update to Elements 2.4.1 and see if that fixes your issue(s).
Be sure to use the “Re-publish All Files” option in the file menu.
Let me know how you get on.
Blumik
(Mike)
May 21, 2026, 6:10pm
8
You are just fantastic Great and thank you very much for the implementation.
Best regards
Mike
I have updated and republished all files. There appears to have been a problem with MAMP as was it was blocking some files from being updated/written. Anyway, thanks for the assistance over the last day or two
