Collections data won't show up
I am working on some experiments with the new collections function. After some puzzling and reading, I think I understand the structure. But for some reason, I’m unable to make the data visible in the edit/preview mode.
The properties from the collections json file appear in the Inspector Pane, but adding new data doesn’t work (for now).
If anyone would like to take a look at where the error might be, I would be greatly helped.
Test project
Hi @Bartje, happy to take a look but you’ll also need to share your Dev Pack!
beat me to it
@dan Sure! How stupid :man_facepalming: and it’s only Tuesday :grimacing:
Hope this link will work.
Got it to work. But not sure what I changed. Give me 5 more minutes.
@dan … this time the component shows up in the browser.
Looks like the opposite problem from mine :rofl:
Shows in browser but not in Edit mode. Restart did solved this.
@Beblebroks What did you do to make it work?
Thats what I am trying to reproduce.
We’ve found the issue and a bug! Give me 5 minutes and I’ll explain all… please hold…
Okay, here we go!
The short answer is you need to change the title from “test” to “bubbles” in the info.plist of the collection.
The longer answer and some tips on debugging is in the video below…
Pfff :sweat_smile: I understood it correctly after all. But I’m glad we found a small bug. And as always: thank you very much for the quick support.
