Collections can not be removed. The show up as removed, but after change to another component and then go back they are there again.
Same for me.
Collections are not fully supported in Custom Coomponents. We’re going to migrate them to work the same as they do in Dev Components.
If you want to use Collections, please do so in dev components for the time being.
Thanks!
