Conditional Forms is now on the Elements Store for $49.99.
It makes Elements’ own Form smart: questions appear only when an answer calls for them, long forms become simple steps, and prices add up as visitors choose. And it’s easy.
Easy to use
- Start with a template. Drag one onto a page and it works straight away: questions, steps, conditions and thank-you messages already set up. Change the wording, delete what you don’t need, done.
- Or add it to your own form. Drop a Show When into any Elements Form, put the follow-up fields inside it, then pick a field and an answer in the Inspector. That’s all there is to a condition.
- Nothing to set up. Elements’ own Form still checks and sends every message, with the email or webhook settings you already use. No code, no PHP, no extra service.
- Hidden questions stay out of the way. A question that isn’t showing is never required and never sent, so visitors only fill in what applies to them.
10 templates, ready to drop in
They’re built from over 700 real forms (about 70 of each kind) and are deliberately complete, so you delete what you don’t need rather than build what’s missing.
| Template | Steps | Fields | Conditions | Also inside |
| Contact Switchboard | one page | 39 | 20 | eight topics, each with its own questions |
| Quote Request | 5 | 63 | 17 | check-your-answers summary |
| Support Desk | 6 | 81 | 53 | steps that appear only for the request type, summary |
| Booking Guide | 4 | 57 | 26 | summary, a thank-you that fits the booking |
| Event RSVP | one page | 30 | 17 | a name and meal for each guest in the party |
| Feedback Follow-Up | 5 | 63 | 29 | follow-ups that change with the rating |
| Smart Order | 7 | 67 | 26 | live price subtotal |
| Application Guide | 7 | 98 | 24 | steps for each role, a guardian step for under-18s |
| Product Finder | 12 short | 30 | 55 | recommends one of your packages |
| Giving Form | 4 | 63 | 26 | running gift total, any amount |
That’s 50 steps, 591 fields and 293 conditional sections, ready to use.
Four components, plenty of options
- Show When: up to three conditions joined by And or Or: is, is not, is one of, is none of, is answered, is not answered, contains, more than, at least, less than, at most (dates too). Show Whens can sit inside each other. Options: Require While Showing, Clear When Hidden, Fill From Page Address (a link ending
?topic=billingopens the billing questions), and a screen reader announcement for new questions. - Form Step: one step at a time with Next and Back. Progress as a bar and step count, numbered steps, a step count, a bar or nothing. Steps that don’t apply are skipped, and steps can have their own conditions. Button color, size, corners, position, arrows and full width on phones.
- Form Total: a live price total from the answers chosen (“Large (+$5)” adds 5, “Adult tickets ($25 each)” counts how many), times a quantity if you like, item by item or as one figure, and sent with the form so your email shows it.
- Form Summary: visitors check their answers before sending, with Change buttons back to each step and a button straight back to the summary.
All four share a Look group (Plain, Indented, Boxed or Line above, with borders, backgrounds, padding and corners from your theme) and a Money group
($, €, £, ¥, ₹ or your own symbol).
The details
- If anything goes wrong, it fails open: every field shows and the form sends as normal (a total or summary hides rather than show a wrong number).
- Screen readers hear new questions and steps, keyboard focus stays where it belongs, and reduced motion is respected.
- Works with Tailwind 3 and 4 themes.
View Conditional Forms in the Elements Store (Elements Required)
More details and screenshots: Conditional Forms for RapidWeaver Elements | Windy Town
All my Elements add-ons: Elements Add-Ons for RapidWeaver Elements | Windy Town
Here’s a little example:
When You Choose the from Drop Down Menu - THE FORM CHANGES!
