Configure Title Type in the Project
Hello everyone
I’d like all the H3 headings in my project to be in a specific font (Arial, for example), a specific color (Text 500), and underlined (Accent 300, offset 10px, and 5px thick).
I saw a possible solution in the Themes section but can’t seem to activate it. Also, it seems to me that the underlining options are more limited than in the module settings?
Do you have any ideas?
you need to use the Typography Component. To have a header text, highlite the text you want to be a H3, in the inspector select h3 from the dropdown.
Thanks for this lead.
Alternatively, use a Text Component, set as you’d like, and then set it as a global and use the text override switch.
