Hi Mike
Did anyone fix your problem with the contact form?
Best Tom
The Contact Form is very robust now, and in the vast majority of cases, any issues users encounter are due to incorrect SMTP settings being entered for their email provider.
Thanks @dan
I’m currently struggling with the settings on my website as well:
Do you happen to have a tip for me? I’m honestly starting to get desperate…
The error on form submissions says email is not enabled for this form.
Have you checked your web host’s guide here Welche SMTP-Einstellungen muss ich verwenden? ?
Hi @differentdan
Yes - I copied exactly those settings.
That’s why I’m so clueless right now…
Hi Dan
I spoke with my provider. All settings are correct and SMTP is also enabled.
I can also log in via webmail and send as well as receive emails successfully.
Best wishes
Hi @Tzatziki
It’s still giving the same error message:
Email is not enabled for this form
Can you create an FTP user for me that I can use to log into your account with and that has access to the web folder where you upload your Elements site to? You can send those FTP login credentials via DM to me here on the forum.
