Contact form problem reappears
I have an issue on a website with the contact form, it works fine on one domain but not on another. I raised the issue with Chillidog hosting and got the following response:
“ hi Dave
this is going to have to go to RealMac to investigate. The settings are correct but it appears to be an issue with their PHP code in Elements. I’ve sent them 1 PHP error log, but there may be another
please reach out to Elements to see if they have any guidance.
thanks
Greg”
Did you get the PHP file?
Hi @jwDave, have checked the support in-box and I don’t see it…
@barchard, can you send it to forumsupport@realmacsoftware.com?
I’ve sent this error to Tom but if you need more info or other files, just let me know. Thanks
Hey @barchard, can you post here on the forum, or email support in future. Thanks!
After chatting with Tom over at Realmac, he suggested we tag @ben to jump in here and help.
@jwDave do you have a live URL I can take a look at? And could you share the project with me, perhaps via a DM if you have any sensitive data in it?
I emailed you at ben@re…
Dave
Hi @jwDave,
just had a look at your project and seen that you have a Form nested inside a Form — remove the outer Form and everything should start working for you!
Let me know how you get on :slight_smile:
Thanks Ben, all sorted, sorry for the issue I caused through my inexperience.
No problem, we’re all learning :smiling_face:
