Containers in a row, side by side
I want to have an image and text box side-by-side, so that our website name is next to our logo.
Flex does not seem to do this
Give it a try with Grid using these settings and see if this works for you:
It does. Set the flex to rows instead of columns.
When is it best to use Grid and when is it best to use Flex?
IMO, I would use the flex in your situation. There’s really no right or wrong as you will see working with elements. It’s very flexible.
See:
Tailwind CSS Docs
Should help.
What a great resource; thanks!
Thanks; now how do I make a text box wider?
My inspector icon disappears every time I shut down, and I have to reinstall it.
My menu bar acquired an image somehow, which I can’t remove, and no menu pages show on any page.
The “remove menu” feature does not work, so that I could add a new menu.
(attachments)
